Author Topic: MkIV throttle cable  (Read 3002 times)
koen
MkIV throttle cable
« on: August 25, 2011, 16:59:29 »
The MkIV of one of my friends had a melted throttle cable surrounding, which causes a sticky throttle cable at 4500 rpm.
   Very dangerous.
   I want to replace the complete cable now, but can anyone tell me
   if there are safer ( I mean with non-melting materials) cables available please ?
   Koen.
MkIV throttle cable
« Reply #1 on: August 25, 2011, 17:53:42 »
If you have time build a linkage with rod ends:
   Very precise.
westcott
MkIV throttle cable
« Reply #2 on: August 25, 2011, 19:02:18 »
If you don't want to go with Peters linkage have a look at Lokar, they have universal braided stainless cables and dipsticks with aluminum fittings and teflon inner tubes. If the wire is damadged one day you can replace it by a standard bicycle brake cable, because the Lokar fittings are screwed.
   See here:  http://www.lokar.com/product-pgs/throttlecables-kickdowns/tc-kd-main.html
   Uwe
Gus Meyjes
MkIV throttle cable
« Reply #3 on: August 27, 2011, 01:22:11 »
Go with the linkage! plus a couple of return springs for safety. It is not that difficult to fabricate, very precise and no melting business!
koen
MkIV throttle cable
« Reply #4 on: September 02, 2011, 10:25:54 »
Thanks for all the input. In the end we decided to go for the linkage.
