... the goal was to replace the existing pump with an exact replacement. So with that in mind I checked the specs on a 1988 Ford Mustang 5.0L EFI motor and came up with 95LPH then researched only 52MM diameter pumps which fit in the original bracket195mm long with the correct fittings on each end ... only one BOSCH pump out of the 2 still made cross references correctly. I just couldnt come to terms with altering the existing mount. They did a great job silencing it from noise and vibration ... unlike the other Fords in the USA ... but it all work out well. The route of the failure was the gasoline sitting in the pumps since 2006. I guess now the gas goes bad after a short period of time.
