To buy or not to buy? That is the question! If you just won the lottery, that is not a problem because you have all the buying power you need to ensure the car and history are perfect. If your budget is restricted, then you need to buy very wisely, and cross check all the history with the registrar before parting with your hard earned cash. Remember, if it looks too good to be true, it probably is! There is a right price for every model and if you believe you can buy a Thames Ditton Cobra for 100k, then you will be disappointed. Once you find a car which fits your budget, you must ensure you are buying exactly what is described, and that it is recognised by the Club Registrar. If there is any doubt, the risk is all yours! If you can't afford the car of your dreams, then look for a less expensive substitute at a price you can afford, and do all your homework again. That way you will eventually own an appreciating asset. When you win the lottery, you can always go back to plan A.
