Originally posted by aex125
As an FYI, I pulled out my NOS quadrant from my 86 Fox body mustang and while the quadrant is mounted differently, it looks like it is the same piece as is shown in the first pic. Jim can probably confirm the P/N but I am guessing the quadrant will be from a Fox body mustang application.
Jay, I managed to get a direct replacement from a local Ford dealer. It is part number 6183029 and was used on the Granada and Sierra, amongst others. It's quite likely that it was also used on a number of other cars.
The direct replacement for the white one that I took off the car (based on it's engineering number 83BB 7L583 AA) is almost identical, but now has a slightly lower radius (45mm), hence after trialing which one had the best gear engagement catch-point, I ended up using the black one which has a slightly higher radius (50mm) than my original one.
I'm now in the process of having a part machined for me, including an adjustor as shown by Steve. Thankfully
