O.K. final comparison of bezels fitting to the MK IV inside release handle housing. They all fit to the handel housing but are all different.
AC Autokraft MK IV, used on Ford Escort MK2, section cut is trapezium, surfaces are polished, clipped with 2 teeth behind the housing, inner length is 80mm, outer length is 96mm. Ford # is 77AB-T226K23AA/BA
Capri 1/2, Granada, Escort repro bezel chromed, section cut is a V, inner surface more angled, therefore the inner length is only 77 mm, outer lentgh is 93mm. This let the end of the lever sit on the inner surface after usage, so the chrome will come off in this area after a while, clipped with the 4 legs to the 4 ramps on the housing.
Capri 1/2 original bezel, section cut is trapezium, top surface has a groove which devides the bezel into 2 different grains, inner grain is polished, outer grain is rough, clipped with 2 teeth behind housing. Inner length is 80mm, outer length is 101mm. Ford # is M80GB-F22620 AA
