Author Topic: Ace battery box  (Read 510 times)
notacarguy
Ace battery box
« on: November 12, 2023, 16:57:44 »
Hi-
Can anyone help me with a photo or description of what an Ace battery box should look like? Here are a couple of photos of what came out of BEX1122. I'm pretty sure the slab of wood and the bits of hardware store aluminum angle are not correct ;) And I know the outer end of the forward bracket needs fixing. Seems like some of the rest might be right or nearly so. Should those 1/2" tubes have those sections cut out of them? And should the 5/16 BSF nuts welded to the brackets all have their threads drilled out?
Thanks!
-Tom
nicksonsticks
Re: Ace battery box
« Reply #1 on: November 12, 2023, 18:39:06 »
Hi Tom
There are some previous posts on this subject, if you type battery tray in the search box you should find some good info and photos.
Let me know if you need any more info.
Nick
notacarguy
Re: Ace battery box
« Reply #2 on: November 12, 2023, 20:47:49 »
Thanks, Nick. I don't know how I missed it the first time, but a more diligent search turned up the thread from 10/22 that showed me what I need to know.
-Tom
