After 3.5 month in the body shop and spending a fortune the car is back at home.
Except the roof every panel (really every) was repaired, modified and/or replaced. The door skins were a horror story of it's own.
You can see that the head light section was completely re-newed since the old version was in such a terrible condition that it wasn't possible to adjust the head lights. The ugly rectangle indicator lamps should be replaced by the Lucas 539 style lamps.
Now, I have to find the middle of the head light section. Not so easy as it seems. First a cardboard model of the head light chrom ring with a defined center must be constructed. This model can be arranged in the section such it looks quite ok. After the center is transfered from the cardboard model to the aluminium I can identify the line on which the indicator lights should be placed.
Unfortunately, to identify the heights of the mounting holes of the indicator lamps the front bumper should be installed. Also these holes were closed since the old ones were frayed. This complete tasks took some hours. Here is the result.
