Author Topic: Vokes Air filter  (Read 706 times)
WGSchmid
Vokes Air filter
« on: September 16, 2023, 09:33:24 »
Good morning,
I am in need of three Vokes Air filter typically used for the Solex carburetors for the Bristol engine. Does anybody either know where to buy them or is prepared to sell a set to me. Thanks in advance and have a lovely weekend
Emjo
Re: Vokes Air filter
« Reply #1 on: September 16, 2023, 13:20:23 »
Suggest contacting IN Racing Nottingham.
James Eastwood
« Reply #2 on: September 20, 2023, 11:00:07 »
These would get you quite close, although I'm not sure the diameter is correct. You could if determined enough fill the two bolt holes and form in 3x countersunk fixings.
https://www.ebay.co.uk/itm/181977395751?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=MzOAHDPYTGC&sssrc=2047675&ssuid=NbehJn30RP-&widget_ver=artemis&media=COPY
« Reply #3 on: September 20, 2023, 11:36:50 »
W G .......
Re : Vokes Air Filters.
Original Vokes Air Filters are approx ..  ..  135mm Diameter and 31mm Deep .
Caution as  each Ace Bristol  is hand built and engine mounts can vary Please  check clearance under the Bonnet / Hood.
 IN Racing offer vast range of Bristol engine parts, alternatively  Try:  Bristol Owners Club , AC Heritage or Aubrey Finsburgh.
Good Luck.
« Last Edit: September 20, 2023, 11:39:42 by AC Ace Bristol »
