Author Topic: My Attempt at a front number plate holder frame  (Read 552 times)
SpqrEddie
« on: May 06, 2023, 16:12:06 »
Hello!
unfortunately the body was already drilled in two points to hold the number plate, but i am concerned that the leverage that the number plate and the braket might do in case the plate is hit it could damage the body panels. As well it might not be very strong.
I didnt wanted to make other holes in the body to reinforce the set up so i came up with another solution.
I made this removable frame.
Now that i have tested it, it will paint it.
Best,
Eddie
