Author Topic: Clutch plate stuck  (Read 552 times)
Lev
Clutch plate stuck
« on: February 13, 2023, 14:43:10 »
Hi
I can’t engage the gears with the clutch depressed.
I’ve tried jacking the rear wheels and running the engine for 30 mins in gear but the clutch is still not disengaging. 1960 Bristol engined Aceca.
Any suggestions gratefully received.
Lev
bennettpg49
Re: Clutch plate stuck
« Reply #1 on: February 13, 2023, 16:13:46 »
Hi, start the car and get the engine up to temperature and turn off. Restart the engine with first gear engaged and the clutch depressed then accelerate hard, if this doesn't work try several more times. Make sure you're on a quiet road!! If you're not too sure ring me on 07976 255202 and I'll talk you through it. Best of luck.
Lev
« Reply #2 on: February 13, 2023, 17:03:13 »
Thank you very much. I’ll give that a try for sure. 🙏
