Author Topic: CLB engine "WT" Suffix  (Read 822 times)
SpqrEddie
« on: January 11, 2023, 09:30:08 »
Hello!
anybody happen to know what the suffix WT means in a CLB engine number?
on the engine block there is also a two digit number stamped in additon to the engine number.
Thanks!
Eddie
AEX146
Re: CLB engine "WT" Suffix
« Reply #1 on: January 11, 2023, 15:44:36 »
Eddie,
When this subject came up before the suggested answer was that WT might stand for Wellworthy which was a piston manufacturer originally based in Lymington. The company merged with other British piston/ piston ring specialists into  Associated Engineering Group in the late 1940s.
Ben
SpqrEddie
« Reply #2 on: January 11, 2023, 17:07:26 »
Thank you!
hopefully i will not need to open the engine soon to confirm this!
Eddie
