so in resumé, for me with standard Mk IV it means following:
- build strut in replacement of one of the bumper horns (to be on/off screwed at Goodwood)
- fix medium size fire extinguisher into cockpit (this is always useful, but only replaces the existing, not solidly fixed system)
- bring along the mufflers I bought at Castle Combe when we had a track day there in the fall of 2009, to ensure the Mk IV meets the noise requirements
put catch tank not knowing what effect the deviation of the recirculation of engine fumes might have on proper functioning of the EFI system, unless I make a recirculation from the catch tank itself, meaning that the catch tank will be in between breather and inlet manifold original "catch tank" setup is OK - throttle return spring is OK
- mark ignition key with on/off signs
- have to check if helmet and overalls are still meeting the MSA spec that have changed this year (this is due anyway though)
quite a bit of trouble, for the sake of being able to just do about 5 laps on Goodwood motorcircuit [
but with the benefit of spending a nice day with the ACOC friends [
