Author Topic: Exhaust manifold 302efi  (Read 8404 times)
« Reply #15 on: May 19, 2013, 15:54:57 »
Here the RH or passenger side of my foot boxes,there are some 20mm space between headers and factory heat shield.
« Reply #16 on: May 19, 2013, 16:00:25 »
On the LH or drivers side the headers (#6 tube) are 1-2 mm away from the factory heat shield. The edge protecting strip melted during the run in because i had the engine timing a bit late.
« Reply #17 on: May 19, 2013, 16:08:00 »
My headers are BBK stainless, 1621SJS, titanium matt coated, for use with EFI.
French Frie
« Reply #18 on: May 19, 2013, 17:41:40 »
You mean JBA, not BBK, right Uwe [;)] ?
« Reply #19 on: May 19, 2013, 18:51:00 »
William, photo posting instructions HERE, and in my post of today(19th May) there is a hint on how to remove the line of code that appears before the photos above.
   Happy photo posting! Nik.
« Reply #20 on: May 19, 2013, 22:09:21 »
Yep..JBA, not BBK.
ANF289
« Reply #21 on: May 20, 2013, 05:37:44 »
Originally posted by French Frie
Oh yeah ! Really tight, indeed ! What is the material of the panel shied added ? No heat problem ? Or burned feet [;)] ?
   Ps : many thanks for this fast answer !
   The heat shield is KoolMat = NASA Thermal Protection System (TPS) materials developed by Rockwell Space Systems (now Boeing North America).  Still warm... but no burned feet!
PS2 : Am I correct if I assume you plugged the air pump lines ?
   Yes, the air pump was removed and the remaining plumbing was capped.
AK1161
« Reply #22 on: May 20, 2013, 16:05:52 »
We managed to use 1 3/4" tube as opposed to 1 5/8" giving better outflow. The origional stuff is certainly restrictive and if you get a chance to change / convert it is a worthwhile upgrade.
   [/URL][/img][/URL][/img][/URL][/img]
« Reply #23 on: May 21, 2013, 19:15:52 »
Nice, it does the trick and looks pretty good.
   Good suggestion for my planned complete exhaust rework during the next winter.
