Author Topic: Starter sylenoid mkiv  (Read 1948 times)
cobradoc
« on: June 12, 2022, 19:22:08 »
Where is the starter sylenoid located on mkiv cobras?
Re: Starter sylenoid mkiv
« Reply #1 on: June 14, 2022, 10:04:06 »
It ought to be on the starter so I would check there first.  If it’s not there then it could be remote so look in area near battery.
FH
silty
« Reply #2 on: June 14, 2022, 20:42:47 »
It's next to the battery.
cobradoc
« Reply #3 on: June 14, 2022, 21:22:24 »
Thanks for the replies, I found the starter sylenoid it is in the compartment in front of the passenger foot box that has the fuses-to access you need to remove battery and plate that the battery sits on-can’t reach from inside car
« Reply #4 on: June 21, 2022, 21:02:52 »
Are you sure thats not the relay rather than the solenoid? My car (CRS) has the solenoid on the starter and the realays in the passenger footbox.
jmohara
  • Owner of AK1099
« Reply #5 on: June 25, 2022, 21:31:12 »
I am pretty sure the solenoid was in the footbox on my early MKIV.
cobradoc
« Reply #6 on: June 30, 2022, 22:15:43 »
Thanks for reply’s I could not see any sylenoid on the starter -it was in the foot box
« Reply #7 on: July 12, 2022, 22:33:07 »
AK 1106 also has the solenoid in the footbox electric compartment.
