Author Topic: 100D2 engine oil leak at rear  (Read 869 times)
rpv1
« on: February 21, 2022, 20:09:00 »
Hello all,  I can't imagine the Bristol engines normally leak out back when stopped a 3-4 inch round puddle of oil.  My 100D2 does.  I know the engine family is a dynamic rear seal technology.  Just thought to ask of any experience, advice as to where to look for the leak before I start dropping big parts, like the trans.  Thanks in advance!
James Eastwood
Re: 100D2 engine oil leak at rear
« Reply #1 on: March 07, 2022, 12:15:40 »
The rear seal will be above the oil level so I wouldn't expect it to leak when parked, unless the oil is draining out of the bell housing. Just make sure your analysis of where the oil is actually coming from is correct, remember windage across the engine can blow oil down the engine is some instances.
I would check the breather, before you start dissembling things.
1) Are blow by gases execessive? i.e. do you have a ring or valve stem seal problem.
2) Is the breather free and working, i.e. is there only a little gas coming out of the breather, but then what may appear to be more when you open the oil filler cap? You might need to ingratiate yourself to your neighbours and give it a rev up.
