Author Topic: Thermostat stuck open  (Read 1129 times)
PaulAnderson
« on: June 04, 2021, 19:05:25 »
So, most of my work on Ae220 has been trouble free but this conundrum needs the expertise of better men.
The thermostat in the pictures is stuck open. Better than stuck closed.
So, I have some questions.
1: How do you get it out of the housing (trying not to damage anything)
2: Can you get replacements?
3: Are there any other alternatives?
Your learned answers very welcome.
Best wishes
Paul.
Re: Thermostat stuck open
« Reply #1 on: June 04, 2021, 20:44:23 »
I note you have removed the grub screw which holds it in!
The thermostat should push out!
Brian Eacott should be able to supply a modern equivalent.
I can supply a new housing which uses a Mishimoto thermostat which have various heat ranges, i have a 68 degree centigrade heat type!!
PaulAnderson
« Reply #2 on: June 04, 2021, 22:04:56 »
Thanks Robin I'll drop you an email. Best. Paul.
