Author Topic: BEX1146 on eBay (again)  (Read 3440 times)
Jim A
« Reply #1 on: November 05, 2009, 16:58:00 »
That is not a bad looking AC, but I wonder if it bothers anyone else that the name "Bristol" continues to be associated with it.
« Reply #2 on: November 05, 2009, 17:48:33 »
   They`ve even taken off the 'AC Bristol' badge & just got the round AC one on the nose!
   (Also, is it actually owned by an ACOC member?)
    I suppose as it was 'born' as a Brizzle (and will always bear it`s 'BEX' chassis no.) it is fair to still describe it as such, even with the Ford V8 in,
   at least they aren`t calling it a CobrAce or AceBra!
   Incidentally, how much torsional strength would this chassis longitudinal and 'X' bracing add?
   Not as much as sleeving, I would guess?
bex316
    • BEX316
« Reply #3 on: November 12, 2009, 01:17:28 »
Auction ended. Highest bid $ 126,100 but reserve not met so remains unsold.
   Jerry
pjbowman
« Reply #4 on: November 12, 2009, 21:21:55 »
Not sure I believe the bid is real, either.
Peter B.
pls01
« Reply #5 on: November 14, 2009, 19:44:55 »
The x-brace adds little to the torsional stiffness since it is all in one plane.
   Note the C channels welded to the underside of the main tubes.
   Welder, check. Scrap iron, check. Case of Bud, check.
Gus Meyjes
« Reply #6 on: November 25, 2009, 19:55:33 »
That is a steep reserve for a modified, non original, car. I realize Ac's have been commanding a hefty value increase over the past few years, but this looks like the 126K should have been right on the money.
   Gus
