Author Topic: Aceca battery tray  (Read 1466 times)
MLeitao
Aceca battery tray
« on: April 17, 2021, 22:45:20 »
Hello all,
In my Aceca, battery in the trunk/boot.
 Does anyone have a picture of the battery tray, in the original location?
For what I have read, it was near the brake/clutch.
Manuel
AK1161
Re: Aceca battery tray
« Reply #1 on: April 18, 2021, 12:00:56 »
This is the location of the battery box on an Ace.......I am unsure if it is the same on the Aceca....if it is then this photo should help.
nicksonsticks
« Reply #2 on: April 18, 2021, 15:11:12 »
Hi Manuel.
I've attached a photo which should help, this is on a 1960 Aceca Bristol, the photo is taken from under the car and you can just about make out the battery terminal, behind the n/s/f wheel area. This is an original UK right hand drive car, not sure if a left hand drive would be a different location?? or if the AC engine version would be different?? Hope this helps a bit .
Nick
bex316
    • BEX316
« Reply #3 on: April 18, 2021, 22:48:40 »
On LHD cars it is on the same left side which is not ideal as the steering shaft above is in the way. You have to lower and lift the battery across it.
Jerry
