Author Topic: Brake Mastervac for MKIV NEED Help  (Read 2986 times)
cobra06FR
« on: March 22, 2021, 17:18:13 »
Dear all,
I have an MKIV 1989 (AK1317).
I just realised that there is a brake liquid leakage between the airvac and the master cylinder of my Brake mastervac.
There are quite few references on the system body : ABCDEGHJKLMN  8  and   74660862   as well as a reference that looks like Q1370?
I have attached some pictures of the system.
Does anyone know what brand and reference it is ?
I would think it is a Ford part but not absolutely certain and maybe an ATE model but I cannot find these references.
Many thanks in advance for you help.
Best Regards
Laurent
Many thanks
Best Regards
L
Re: Brake Mastervac for MKIV NEED Help
« Reply #1 on: March 23, 2021, 08:04:57 »
I think it's a Girling part from a Ford Granada MK I 1972-1976, but I am not sure.
paho
« Reply #2 on: March 23, 2021, 11:45:06 »
Noticed post on the Cobra forum regarding a master cylinder with the same markings. See:
http://www.cobraclub.com/forum/showthread.php?t=43512
Its off a Sierra Cosworth, but you need to read the whole thread. It can well be the same item as the Granada mentioned in
the previous post, but I've looked at a picture of one from a '78-'81and that has three brake pipe conections, the earlier model only
appears to have two connections. Compare pics for '72-76 and '78-'81
https://en.bildelsbasen.se/?link=item&searchmode=1&vc1=136&pc1=105&vc[0]=136145100&vcx=2460&pc[0]=105103101&post_id=40768315
https://en.bildelsbasen.se/?link=item&searchmode=1&vc1=136&pc1=105&vc[0]=136145100&vcx=2461&pc[0]=105103101&post_id=8399783
Hope this helps /Paho
COB 302
« Reply #3 on: March 23, 2021, 16:01:34 »
Here is the original Ford part number. I found a NOS master cylinder after a long search on ebay UK.
« Last Edit: March 23, 2021, 16:09:42 by COB 302 »
jmohara
  • Owner of AK1099
« Reply #4 on: March 24, 2021, 13:21:56 »
I had the same issue - got a kit from www.powertrackbrakes.co.uk and rebuilt the master cylinder. Cost £18. Works great.
M
COB4
« Reply #5 on: March 27, 2021, 10:40:58 »
This info relates to the Master Cyl. fitted to 1260 and 1271.
Lucas/Girling Part No. 74066315
Ford Part No. 6118138
It has a 7/8" or 22mm bore with 3 outlets
The No. 74660862 is the casting No. on the side of the body
This Master Cyl. is fitted to various Ford Sierra models from 1982 to 1986
The Lucas/Girling service kit No. is SP 7704
I have a spare of both the above if anybody is interested
cobra06FR
« Reply #6 on: March 27, 2021, 18:29:47 »
Dear COB4, JMOHARA, COB302, PAHO, dkp_Cobra
Many Many thanks to all of you. I am sure I'll find the part now with the info you provided me with.
I am really thankfull to all of you for your time and investment to help me sort that out.
Best Regards
LaurentCobra06
Many thanks
Best Regards
L
