HI
Finally, finished install of twin leading shoe brake setup on the Ol' Girl. Had a bit of delay after finding one of the wheel cylinders that I had refurbed and lined etc by Past Parts, had a crack in the casing near the bleed/pipe connections and was leaking and taking in air. No wonder I could not get the buggers bled. Thankfully Powertrack had just the right item to replace it, the last one they had, Phew
Cannot get her out on the road as yet, as still awaiting the return of my front wings from the sprayer. Still on the area in front of my garages she stops rather well, especially with the servo.
I will still be working on a disc brake conversion (Found some Chevy discs that almost fit right PCD but need centre bore opening machining out a bit) once I have sorted out a few other bits on the Ol' Girl while she is off road. ie new gearbox tunnel, new carpets and drivers seat splits and cushion repaired, using C A Upton in St Leonards a very old family run business.
Hope all going well with you all in these trying times.
Cheers Gary
