Author Topic: Lucas distributor DX6A wanted!  (Read 2909 times)
AEX 31
« on: August 28, 2020, 10:41:54 »
Dear All,
I'm looking for a Lucas distributor DX6A, 40143E for an AC engine.
Any condition can be of interest! So if anybody has one or knows
of one that is for sale, please contact me.
I can be reached on my mobile +46709266070 or my email:
jonas (at) jonaslindvall.com
Thanks. Jonas
Re: Lucas distributor DX6A wanted!
« Reply #1 on: August 28, 2020, 13:20:06 »
Jonas
You can get distributors from the Distributor Doctor set up with the best Advance curve, '  martin@distributordoctor.com  '
Robin  '
AEX 31
« Reply #2 on: August 28, 2020, 13:32:47 »
Dear Robin,
Thank you. I did check with Martin and he doesn't have any "donor" DX6A
bodies at the moment.
I intend to use him if I do find a distributor, regardless of condition, at least more
or less regardless!
You wouldn't happen to have an old one in corner some where?!
Kind regards
Jonas
« Reply #3 on: August 28, 2020, 15:08:09 »
Jonas
I do have a small number but they, as you have found are difficult to find, Martin has 23D6 which are supposed to be better i believe, have purchased a couple for  some engine builds!
Have you tried Rod Briggs?
AEX 31
« Reply #4 on: August 31, 2020, 06:23:57 »
Robin,
Thank you. Yes I have tried Rod. Maybe I should consider trying
the 23D6.
Is there anybody out there with experience fitting one to a AC engine?
I would appreciate any feedback.
Kind regards
Jonas
« Reply #5 on: September 01, 2020, 13:12:24 »
Jonas
A good reason for using the 23D6 is that the shaft bearing support is greater than the DX6A, as you appreciate the side loading from the gear does require good shaft support! 23D6 is a better distributor for the application.
AEX 31
« Reply #6 on: September 03, 2020, 03:34:37 »
Robin,
Thanks for your input. Yes this does indeed make a lot of sense.
In actually fact, the reason for me looking for a new distributor
is that my old one, only some 5000 km after having been rebuilt,
is showing clear signs of what problems side load on the shaft can
cause!
Anybody out there having had any experience with the 23D6 that
is made by Crosswait & Gardiner?
Thank you.
Jonas
« Reply #7 on: September 03, 2020, 09:20:35 »
Jonas
Your distributor is fully made by Crosthwaite & Gardiner & they changed the shaft & bearing design to have a ball race at the top of the shaft & a needle roller at the bottom, the Lucas design uses plain Oilite bushes, Martin Jay has looked into changing the bush to a needle roller bearing but due to the shaft diameter has not found suitable bearings.
Martin believes as the Oilite bushes are full length it gives adequate support to the shaft in this application, so does not believe a change is necessary.
One of the problems using roller & ball race bearings is lubrication which does not exist in this application as the distributor runs without any oil supply! Oilite bushes on the other hand are impregnated with oil as it is a sintered bush, I am sure Lucas did extensive wear rate life tests when they designed the distributor & found this plain bearing design works!
One would expect shaft wear over time with the oilite bush design, but clearly it works!
I suggest you contact Crosthwaite & have them repair the distributor, i doubt Martin would wish to repair it as i would expect it would fail again!
TTM
« Reply #8 on: September 03, 2020, 22:55:53 »
Jonas,
As an additional option you could get in touch with Bristol specialist Geoff Dowdle. His email address is : geoff.dowdle AT gmail.com
Geoff knows a thing or two about the various distributors which can be used on the Bristol engine and may be able to help.
Thomas
