Author Topic: Dual left exhaust pipes  (Read 3736 times)
AK1131
« on: May 27, 2009, 15:50:58 »
My 1986 MkIV is equipped with dual exhaust on the left side. I have seen a couple other MkIV's with this feature. Looks like it is period to the mid 80' models. I have also seen it on Bristols. Personally, I like it. A very nice departure from all the plastics. Does anyone know the history of this design?
   AK1131
« Reply #1 on: May 28, 2009, 00:48:36 »
The carbed cars had these, the mid 86 on fuel injected cars got the single left/right pipes. As the USA cars had to "piggyback" on the Mustang certification for EPA, Autokraft was limited as to what they could do to emissions related systems.
« Reply #2 on: May 28, 2009, 02:35:36 »
thanks Rickers
AK1131
« Reply #3 on: May 28, 2009, 17:08:59 »
Thank you Mark IV. I knew you would have the answer.[:)]
ak1087
« Reply #4 on: May 10, 2011, 19:39:26 »
I have the same setup on my MKIV, AK1087.  I am looking for a source to buy a proper dual exhaust setup like on the '87 & later cars.  I don't need the cats, just the proper mufflers & head & tailpipes.  Anyone know where I could get one?
AK1161
« Reply #5 on: May 10, 2011, 20:38:37 »
Just had the engine and exhaust system rebuilt by Wealden Engineering and it is quite simply a work of art with hand built headers and boxes and 1 3/4'' stianless tube. Sounds amazing and recommend you get in touch with Frank Catt.
   info@wealdenengineer.co.uk
   Picis to follow
AK1161
« Reply #6 on: May 10, 2011, 22:09:19 »
g]][/img]
marklotus
« Reply #7 on: May 11, 2011, 20:44:29 »
I have AK1121, which is a US spec carb car.  It came with a single exhaust system with dual outlets on the left sde.  I was able to convert to a true dual exhaust system with a muffler under each side(door).  I utilized the original polished tips for the tips of the new system, one tip at each side.
