Author Topic: Steering column vertical adjustment  (Read 1091 times)
SpqrEddie
« on: November 07, 2022, 01:15:06 »
Hello!
in order to adjust the steering colum, it is sufficient to slaken only the bolt on the braket behind the dash panel or as well the bolts connecting the steering box to the frame?
Thanks!
Eddie
SpqrEddie
Re: Steering column vertical adjustment
« Reply #1 on: December 17, 2022, 02:00:27 »
it is necessary as well to lose the 3 bolts that hold the stering box to the frame otherwise the column doesn't move.
nicksonsticks
« Reply #2 on: December 17, 2022, 11:44:18 »
Hi Eddie,
Sorry I haven't got a definitive answer for you, but it would seem logical to me that to get the maximum amount of adjustment without putting an excessive amount of stress on the column you may also need to loosen the lower mounting bolts.
Hope this helps a bit.
Regards.
Nick
SpqrEddie
« Reply #3 on: December 19, 2022, 13:36:05 »
Thank you Nick,
I confirm that it is necessary.
As you mention it is necessary otherwhise you bend the steering column.
I did it last firday.
Thanks!
Eddie
