AC Owners Club Forum => Mk IV, Superblower, CRS and other Continuation Cars Forum => Topic started by: Baz on April 28, 2020, 14:21:05
any one know where the door hinges originally came from or did Autokraft make them mine are getting a bit sloppy regards Baz
Door hinges are fabricated, massive steel parts and not from other production cars. First check the door bolts / pivot pins. You need to remove the covers between door and instrument panel kept by 2 screws. One small screw is on the top of the cover visible from below, the other one is covered by the carpet below the door hinge.
once again thanks for help Baz
