AC Owners Club Forum => Vintage, PVT & 2 Litre Forum => Topic started by: jonto on December 02, 2015, 18:21:25
Title: Car No 6199 1921
Post by: jonto on December 02, 2015, 18:21:25
Long on going project, will post more as things progress-
Post by: dkp_cobra on December 03, 2015, 06:33:37
How to post pictures:
   http://www.acownersclub.co.uk/forum/topic.asp?TOPIC_ID=2560&SearchTerms=how,to,post,pictures
Post by: jonto on December 03, 2015, 11:37:38
Thank you Cobra, have it now[:)]
Post by: Old Crock on December 03, 2015, 18:54:01
Thanks for the pic; a very early 4-cylinder (Anzani-engine), with single-pane windscreen (which has an exposed lower panel due to straight screen frame vs. curved bulkhead). No front wheel brakes, of course.
   Good luck with your rebuild and please keep us up to date. What's that next to it, an Alvis?
Post by: GSouthee on December 03, 2015, 19:27:29
Very nice Car indeed.
Post by: jonto on December 03, 2015, 20:10:43
Yes next door 12/50 Alvis
     Engine No 2237, has piston type oil pump, exhaust manifold integral with block and priming taps in the head. Car is some 200 odd earlier than the four seater that used to be at Beaulieu, yet was registered some weeks later, third quarter  of 1921. Southampton registration, cast aluminum number plate bears a north London makers name.
     Almost ready to build the engine, just working on a test rig to run the oil pump.
Post by: Old Crock on December 03, 2015, 23:20:56
Another feature that ages this vintage AC is the U-shaped headlamp brackets. Early cars, like this, also had one door only and a central running-board spare wheel. Here's a pic, and specification, from the 1922 brochure (it should be readable but might need downloading and enlarging). Note the oil consumption quoted - 600 miles per gallon (= a pint every 75 miles).
   (http://www.seabirding.co.uk/images/P2Small.JPG)
   (http://www.seabirding.co.uk/images/P1Small.JPG)
Post by: jonto on December 04, 2015, 13:36:31
Headlamps from this car have adorned the front of 31225 for the last 40 years-
   The pistons have no oil rings, two substantial compression, then a groove with drain holes-
   The residue of the oil in the sump stuck to your skin like tar, almost impossible to scrub off!
   The valves have no guides, run direct in the iron block, unequal stem diameters, the inlets larger than the exhausts, perhaps Anzani's were using up old stock left over from their cancelled aero engine contracts. The amount of carbon deposit under the exhaust valve heads had to to seen to believe! Bit plasticy to not hard, benzol based fuels were popular I believe, not the volativity of today's fuel. I remember a picture of Birkin filling his Alfa during a TT, would be 1931 I guess, big funnel in the tank, emptying a churn into it, fuel sloshing all over and he has a fag in his mouth!
Post by: Old Crock on December 04, 2015, 17:39:07
That is a very smart-looking car! A much later vintage 4-cyl, now with 2-doors, entry steps, and with the spare wheel mounted into the wing and running board. It has 4-wheel brakes, so probably around 1927 model and, interestingly, four stud hubs. Nice car Jonto!
Post by: jonto on December 04, 2015, 20:58:50
I sold 31225 over 30 years ago, don't know who has it now, picture from the Bath and West Show summer before last. It is a 1927 car registered 1st January.
   Connecting rod from the Anzani engine, minus white metal babbit bearing-
   Crankshaft assembly-
Post by: jonto on December 05, 2015, 11:43:24
Crankcase and sump, piston type oil pump operates from an eccentric on the camshaft via a push rod and return spring-
Post by: BE774 on December 05, 2015, 12:14:06
Great thread, please keep posting as progress is made! Graham.
Post by: Old Crock on December 05, 2015, 12:34:35
It would seem that the AC in the top photo (CR6208) is the oldest surviving 4-cylinder Anzani-engined AC and, indeed, is the oldest surviving vintage-period AC. Earlier AC's; only the few pre-WW1 Fivet-engined Edwardians and the Sociables and Box pre-date it.
Post by: jonto on December 05, 2015, 20:46:39
There may be an earlier car. I went with some friends in the 1970's to see one in the garden of a house at Neston on the Wirral, it had been replaced by a later car, a 1932 model I was told, I never saw this car as the owners were deceased and it had already been purchased from the estate. The earlier car had been turfed out into the open to weather the elements and was a bit distressed, I remember I could not find the car no plate but it was similar to the one I have so could have been earlier. I heard later that someone on holiday in the area was told about it and took the remains away, to Scotland I think.
Post by: jonto on December 06, 2015, 11:26:30
Back to 6199. Here is the last tax disc the car wore-
   Story is that the car was taken off the road because the engine was tightening. When I stripped it the big end bearings were mauled, the white metal cracked and breaking up. There was dirt in the sump, the piston type oil pump requires a none return valve to develop pressure, if there was dirt around and it was not seating there would be little or no oil circulation and I guess the big ends would be the first to suffer. The crankshaft journals are standard size 1-3/8th inch with little wear, same for the bores and pistons, 69mm.
Post by: jonto on December 06, 2015, 11:36:35
Here's a rough assembly I did some time ago-
   The car was at Little Lever a village near Bolton, Lancs, it was known to the locals but had not been seen for a long time. Then one weekend the local Milkman, Bernard Moynaham when calling to collect his money found the elderly owner in a talkative mood and managed to buy it. Later when he went to collect it he found the garage in a bad state and it had rained over the years, the body was beyond hope as were the beaded edge wheels, rotted where they had been touching the floor. So he passed it on to me as spares for the car I was running at the time.
Post by: jonto on December 10, 2015, 11:52:59
Upperc rankase, sump.
Timing chest gasket, jut need to trim, the faces on the aluminum castings seemed to fragile to use the tap it out with a hammer method-
   External drive to rotate the camshaft and thus run the oil pump to check its output-
   I had to let a new piece into the nearside of the chassis frame, made new front engine plate and the two rear engine/front spring mounting plates but steering box plate is an original, from the late Hugh Lupton along with the well base wheels and other useful bits.
Post by: jonto on December 18, 2015, 11:48:48
Crankcase with shaft.
Oil pressure test, relief valve opens at 20psi.
Post by: jonto on December 21, 2015, 11:49:14
Cylinder block and head.
Post by: dsjw1 on December 22, 2015, 04:02:14
Great job of posting pics! We need more like you to share their interesting projects and details! Thank you!
Post by: REV on December 29, 2015, 19:32:19
I'm enthralled by your project. Keep it coming!
Post by: jonto on January 10, 2016, 21:29:54
Anzani the right way up at last-
   ...hope I put the crank in the right way up, one speed forward and three in reverse  [:0]
Post by: jonto on January 18, 2016, 22:29:46
Anzani valve gear, roller cam follower, peg valve collet.
Post by: jonto on January 19, 2016, 14:23:17
Engine back in its rightful place, with a lot of help from a good friend who's done some nice detail work-
Post by: jonto on January 25, 2016, 17:38:39
Transmission, axle has three sets of numbers-
   F815
   G1042
   6573
Post by: jonto on February 10, 2016, 20:08:28
Next, the clutch, here's the parts-
   Bottom right, the tubular steel part screws on to the crankshaft and doubles as a flywheel nut and support for the cast aluminum clutch plate which is bushed and runs on the outside. This provides the idler bearing that takes up the difference in speed when the clutch is parted. Bottom left the double helical spring lives inside the tube and thus is out of sight when the clutch is assembled
Post by: jonto on March 05, 2016, 13:00:34
Drive shaft, clutch to universal joint-
   The square tooth coupling on the right takes the drive from the clutch, then below the clutch fork and thrust bearing. Above the steel disk is a clutch brake, then left the universal joint blocks  and spider. The whole shaft moves back to open the clutch, the sliding block universal joint taking the movement.
Post by: jonto on April 05, 2016, 12:45:52
Clutch and drive assembled, pedals and linkages-
Post by: jonto on April 11, 2016, 12:32:06
Claudel Hobson barrel throttle carburetor and throttle pedal-
Post by: jonto on April 12, 2016, 12:27:37
AC's own built worm and wheel steering box, hand throttle and ignition levers-
Post by: jonto on May 04, 2016, 13:06:51
The beginnings of some coachwork...
Assembled the steering gear, just under three quarter turn on the wheel from full lock left to full lock right!
Post by: jonto on June 20, 2016, 12:57:42
Next the rad. Has any one had a vintage radiator re-cored, any recommendations?
Post by: Flyinghorse on June 20, 2016, 21:26:00
I was going to do this on my Swift,but decided against it as there was a long waiting list from the preferred repairer,and its very expensive.
   I decided on using Fernox central heating system cleaner ,sitting in rad then power washing out. I then used "alumaseal" for any small leaks as its a low pressure thermo siphon  system. Luckily my radiator was servicable.
   The name of the repairer escapes me but they are in the back of the "automobile" magazine.
   Steve Gray ,AC Heritage may also know having prepped his car for Peking Paris.
Post by: jonto on June 24, 2016, 13:11:33
I have two radiator's. the original one to the car, there is corrosion of the copper core, the second one is in a better state except for crushing at the bottom where vandles had tried to wrench it from its chassis. So I have to have a rebuild, has anyone had the work done and has any recommendations?
Post by: jonto on September 12, 2016, 13:03:07
I was at Lowton Park yesterday, the ex Condon 1924 12hp was there now in the hands of Kieth Hill. I learned that a vintage radiator has been successfully rebuilt by a firm in Wakefeild, I'll make inquiries there.
Post by: administrator on September 13, 2016, 10:03:17
Two possibles are:
   http://www.aaronradiator.co.uk/pages/Vintage_Car_Radiators.html
   http://www.coolexperts.co.uk/motor-vehicle/vintage-veteran-classic/
Post by: jonto on December 04, 2016, 21:50:58
The radiator is now away for the rebuild, it will be some time.
Post by: jonto on February 24, 2017, 12:21:37
I have not posted here for a while, but work has continued, fuel tank, windscreen, dash and instruments.
   Does anyone have a picture of the three seat "cloverleaf" model that was available 1919/20? I believe one is featured in an article in the Light Car and Cyclecar of the period.
Post by: jonto on March 16, 2017, 11:30:49
New silencer from the exhaust shop [:D]
Post by: jonto on March 28, 2017, 12:52:23
Steering gear and exhaust installed.
Post by: Old Crock on March 28, 2017, 15:22:52
Jonto, could you let me know the company that made your silencer. Send me a pm if necessary.
   Many thanks!
Post by: AC Ace Bristol on May 07, 2017, 18:19:45
John.
   Just an Idea,  Fire a email with a link to Simon Taylor.  As well as being a Mine of information, associated with motor journalism,  he is also a ACOC Member ( 2.6 Ace ) and has a massive reference library.
   If he hasn't pictures and details, maybe he could put a request in a future issue of Classic & Sports Car...[;)]
   Will confirm his email address and tel number via email. [;)]
   Great thread, following with interest and looking forward to seeing this AC on the road.
   Cheers for Now
Post by: administrator on May 08, 2017, 09:18:29
Perhaps try the VSCC library at Chipping Norton?
Post by: ACOCArch on May 25, 2017, 01:14:40
Originally posted by jonto
 I am still looking for, without success so far, for the Light Car and Cycle Car article 1919 with pictures of the three seat cloverleaf model.
   1919 LC&C and Cloverleaf model is on the list to investigate at my next visit to the British Library. They claim to have a copy of every British magazine ever published - and so far have not failed!
   Regret Burnard's papers are not in the ACOC Archive
Post by: jonto on October 08, 2017, 17:11:43
I hear the radiator rebuild is done now ans it should be back with me in a few days.
Post by: jonto on October 17, 2017, 12:51:28
Well its running, after 85 years in hibernation.
   https://www.youtube.com/watch?v=mrLIINpKXp0
Post by: BE774 on October 17, 2017, 13:48:21
Although I couldn't see you photos for some reason, I congratulate you on this fantastic achievement!
   Thanks for posting.
Post by: jonto on October 17, 2017, 15:33:51
Its a video, struggling to add it!
Post by: BE774 on October 17, 2017, 21:25:26
All working well now, though!
Post by: jonto on October 17, 2017, 22:45:03
Wanted to display the video on these pages, but cant manage to do it.
Post by: Jam2 on October 19, 2017, 12:36:00
Most sincere congratulations, thanks for sharing, greatly appreciated.
Post by: jonto on October 19, 2017, 14:27:26
My attempts at a "three seater", have to teach myself panel beating now!
Post by: jonto on October 21, 2017, 12:57:14
Title: Re: Car No 6199 1921
Post by: jonto on January 27, 2018, 21:18:28
Not powering an AC but another famous Anzani engine  running-
https://www.youtube.com/watch?v=RkJymMK33Zk
Post by: jonto on January 31, 2018, 17:36:42
Door lock, handle, aluminium switch box and bezel wind clock.
Post by: jonto on September 15, 2018, 17:34:40
Update, progress, ready for panelling now.
Post by: jonto on September 15, 2018, 17:38:52
Side view-
Post by: jonto on September 15, 2018, 17:44:57
Rear-
Post by: jonto on November 13, 2018, 13:41:57
Ordered aluminium sheet for the body panels, new area for me, but gotta do it!
Post by: jonto on July 01, 2019, 03:10:25
I'm still working on it, but bodywork is a long winded job, when your not quite sure how to do it!
Post by: jonto on July 17, 2019, 19:33:50
Sometimes it seems you have taken a step backwards-
Post by: jonto on July 17, 2019, 19:35:42
It feels like your doing a fitting for a bespoke suit-
Post by: jonto on July 19, 2019, 11:47:29
Still a lot to do, shaping up, beading.
Post by: jonto on July 19, 2019, 11:48:27
Post by: jonto on July 19, 2019, 11:49:14
Post by: jonto on October 13, 2019, 15:18:42
Post by: jonto on December 03, 2019, 22:49:42
Done a bit more, beading to the panels, running boards and spare wheel mount, though I'll need more timber for the boards, dimensions are a bit guess work first try!
Post by: jonto on May 16, 2020, 18:13:21
Update, no so much to do now, I have some rear wings I can use, but no stays, conversely, I have the stays for the fronts, but no wings   :)
Post by: jonto on May 16, 2020, 18:14:20
Post by: jonto on October 12, 2020, 12:41:41
Update, the bodywork is not far from completion now, I am currently working on the mudguards.
Post by: jonto on May 17, 2022, 11:51:59
Getting there.
Post by: B.P.Bird on May 17, 2022, 19:05:46
Great looking machine, she will be loads of fun
Post by: jonto on January 30, 2024, 12:31:51
A bit more progress. The early type windscreen and CAV "Torpedo" lamps.
Post by: Old Crock on January 30, 2024, 20:31:53
It's coming along Jonto!
Post by: B.P.Bird on February 01, 2024, 00:13:12
Something to be very proud of - well done
Post by: Jam2 on February 01, 2024, 17:09:28
Many congratulations, the dash looks wonderful too, is it the original?
Post by: jonto on February 01, 2024, 22:02:41
No I have the original, this is one I found at Beaulieu many years ago, its the same, I have the original but this has less holes. It was fully instrumented too, some handy spares.
Post by: jonto on February 09, 2024, 20:51:14
I have some parts that I do not need. Four cylinder bonnet top, couple of four stud wheels, some rear brake shoes large drum, and more, I'll get around to listing them sometime. Anyone have a couple of bonnet handles they dont need?
Post by: AC-Crankcase on February 11, 2024, 11:31:59
I could well be interested in the bonnet top as mine is a home made affair, sorry I do not have any spare bonnet handles,
Dr Tom Dine - Dr_Tom_Dine@hotmail.com
