AC Owners Club Forum => Vintage, PVT & 2 Litre Forum => Topic started by: GSouthee on June 02, 2022, 16:13:52
Title: What Ohm range
Post by: GSouthee on June 02, 2022, 16:13:52
Anyone know the ohm range of the fuel gauge on a 2 litre saloon.
Title: Re: What Ohm range
Post by: Big col on June 02, 2022, 20:41:28
Sorry, I haven’t a clue. But just wanted you to know there is someone listening on the forum. Fingers crossed you get to know.
Post by: GSouthee on June 03, 2022, 18:07:10
Cheers  Col
Hope your car is going well.
G
Post by: dkp_cobra on June 04, 2022, 09:21:28
Gary,
do you still have an old fuel sensor working? In that case just measure the resistance.
Post by: GSouthee on June 05, 2022, 12:28:02
Hi Peter
Already tried that, but sender dead. I may have to use an ohm matcher if I get an after market sender.
Post by: paho on June 08, 2022, 19:08:41
Your fuel gauge sender problem peaked my curiosity. I have a similar problem with mine, but at least the part number is stamped on mine, though I can't get the d...mn thing out of the tank! I usually try and clean the surface of the rheostat which works for a while.
 I searched on AC 2 litre and found the following two sources of information, the later being useful for all AC models. They were www.ac2litre.com which gave me the link to www.holden.co.uk.
I then searched on the holden site for "fuel tank sender". Some of the items have a video explanation basic principles of how they work
e.g. https://www.holden.co.uk/p/sender_for_original_moving_coil_gauges_two_terminal_ , sender for an XK140. Didn't look for one for your AC but maybe you can do an occular comparision or give them a call? They also listed a device to match sender to gauge.
Hope this helps.
/Paho
Post by: GSouthee on June 09, 2022, 08:59:09
Hi Paho
Yep tried Holden no joy.
I can get a choice of senders that will fit but have various ohm ranges. So will probably go for an Ohm matcher.
Great info though from you, cheers.
The joys of old cars.
