Author Topic: ACE Dynamo Type and Rev Counter take off  (Read 3976 times)
PaulAnderson
  • Currently getting AE220 in fine order.
« on: July 31, 2017, 08:30:48 »
   Could someone tell me the Lucas Dynamo number/type for a UMB engined ACE? C39? C40?
   Also, where is the takeoff for the rev counter cable?
   Many thanks
   Paul
SBB
« Reply #1 on: August 01, 2017, 00:11:45 »
Moss Europe can supply the little gearbox which takes its drive from the back of a dynamo which has that facility. I know that Austin Healey Sprite and MG Midget were do equipped. I presume Moss will know which model the dynamo is.
« Reply #2 on: August 01, 2017, 10:00:09 »
Paul
   The rev counter is driven through a 3-1 gearbox from the cross shaft drive, the special gearbox is fixed to the distributor mounting housing on the nearside of the engine!
Klassik Metall
« Reply #3 on: August 01, 2017, 10:19:24 »
The correct dynamo for an AC engined Ace is a C39 PV2 Lucas Part No. 22258E. The correct pulley is a cast alloy type with integral fins.
   The 3:1 ratio tacho drive gearboxes were only fitted to the Ace & Aceca, as the 2 Litre wasn't fitted with a Tacho. Unfortunately these small gearboxes are made of solid unobtainium, I was searching for one for four years before one eventually turned up on Ebay.
   Regards Luke.
« Reply #4 on: August 01, 2017, 11:35:41 »
Luke & Paul
   I had some of these tacho drive boxes made last year & still have a few in stock!
PaulAnderson
« Reply #5 on: August 01, 2017, 16:52:50 »
Thank you both.
   Robin I have sent you an email.
   I have a picture given to me by Will on this forum. Not sure how to post it here fro reference?
   Best wishes.
   Paul.
Klassik Metall
« Reply #6 on: August 02, 2017, 17:21:34 »
Hi Robin,
   Thanks for the info, I have a friend who has also been searching for one of these tacho drives so I'll pass on your contact details to him.
   Regards Luke.
PaulAnderson
« Reply #7 on: August 21, 2017, 14:07:10 »
Thanks to Robin Woolmer I now have an angle drive.
   Best wishes
   Paul.
