Author Topic: 'tool time' story: how I recreate my MK 4  (Read 104802 times)
« Reply #195 on: October 16, 2009, 18:23:05 »
Maybe, some of you think that I am quite happy because the car is finished and I have nothing to do. That's not the case. There is still one problem. In low speed (up to 60 km/h) during change of load I have a beat in the car. I guess it come from the rear axle. I changed all universal joints from the half-shafts. No improvement. I changed two of the rose-joints. No improvement. Now, I change the complete half-shafts:
   (above the new one, below the old original one).
   What should I say: no improvement  :( Now, I have nearly no idea what it can be. I start thinking about a new hobby, maybe collecting stamps ...
« Last Edit: April 18, 2018, 10:46:19 by dkp_cobra »
« Reply #196 on: October 16, 2009, 19:50:32 »
Just a thought, should the joints be at 90 degrees to each other?
« Reply #197 on: October 17, 2009, 09:56:39 »
   The joints must be in one line. The new one is correct but the old haft-shaft wasn't. But there is no way to bring it in one line.
« Reply #198 on: October 22, 2009, 18:16:03 »
I had a short trip with my father-in-law. His spontaneous answer was that the gear slams to the frame. What should I say? I think he is right:
   Today I removed the mounting bracket of the transmission. That doesn't look ok:
   You can see where the bolt of the gear hit the bracket every time when the gear flipped back during change of load.
« Last Edit: April 18, 2018, 10:47:42 by dkp_cobra »
« Reply #199 on: November 27, 2009, 10:03:45 »
If you ask me why I spend to much time (and money) for the restauration of an old car the answer is quite simple: it gives me a good reason to buy new tools [:)]
   For example this digital protactor:
   I used it to measure the old angle of the motor/gear. After removing the old gear mount and fitting the new one I used the digital protactor to find the right angle:
   You can see I have to lower it 1.1°.
   The other new tool is a wig/mma welder. Here you can see the new gear mounting bracket:
   I know the weldseams are terrible but it is my first work and I am quite pride on it. It is really exciting to lie under the car with a welder in the hand and to know that the fuel line is quite near [B)]
« Last Edit: April 18, 2018, 10:48:36 by dkp_cobra »
cobham cobra
« Reply #200 on: November 27, 2009, 15:02:51 »
Thank you for the updates, I always look forward to your posts.
   When you have finally finished your car will you be taking bookings from other MkIV owners ?[;)][;)]
   Have a good weekend - John.
« Reply #201 on: November 29, 2009, 16:11:29 »
Hi John,
   yes, I had a nice weekend, thank you. I started to look for a friend for my snake. I think a cat would be nice but I don't know whether it should be an english cat:
   or an italian cat:
   Please, can anybody help [:)]
« Last Edit: April 18, 2018, 10:50:43 by dkp_cobra »
« Reply #202 on: November 29, 2009, 16:29:34 »
Originally posted by dkp_cobra
   ...I had a nice weekend, thank you. I started to look for a friend for my snake. I think a cat would be nice...
   Oh no, you are beyond help! [8D]
   Never mind a friend, it looks like a great-grandparent is waiting there, behind the english cat!!!
« Reply #203 on: November 29, 2009, 16:39:13 »
Hi Peter
   Stop ...   ...  Pusssseee Footing Around,  Keep with AC's  buy a Ace Bristol.
   And Enjoy ! OK not as fast as your COBLER oooopps Sorry COBRA, but a true companion in the garage...  Both Black.
   Both to your high standard    WOTAPAIR.
   (No, No! No need to get smutty.)
   Mind you a Wee Black Ferrari 275 or 250SWB would really set the cat amongst the pigeons.  Yep!  We have a decision the
   250SWB [8D] any colour as long as you are paying [;)]
   Keith [:)]
« Reply #204 on: November 30, 2009, 11:56:36 »
   Yes, but the grandparent is open and I am looking for a coupe.
« Reply #205 on: November 30, 2009, 12:00:40 »
Originally posted by AC Ace Bristol
Hi Peter
   Keith [:)]
   Mmh, 275 or 250 SWB? Quite nice, but unfortunately not my league. But if you want to support me ... [8D]
   Maybe some of you has an Aceca in it's garage and think "well, I don't really need this car. If I only know of a person how would enjoy it ..." Here I am [;)]
Gus Meyjes
« Reply #207 on: February 09, 2010, 07:57:25 »
Originally posted by Gus Meyjes
Did you get this one?
   http://rover.ebay.com/rover/1/711-53200-19255-0/1?type=2&campid=5336506384&toolid=10001&customid=&ext=280447960583&item=280447960583
   Yes, but the car is finished. Nothing to do for me [:)]
« Reply #208 on: February 18, 2010, 12:27:09 »
Maybe this winter will end some day. Then I would like to start the new saison with nice wheels. So I depainted the wheels:
   Next steps will be painting and polishing.
« Last Edit: April 18, 2018, 10:51:38 by dkp_cobra »
« Reply #209 on: February 21, 2010, 08:09:34 »
They look like like old magnesium wheels now, Cool! I guess the Mercedes rim isn`t your spare?!
