Author Topic: Aceca Window regulator  (Read 661 times)
MLeitao
« on: May 03, 2023, 00:03:39 »
I need for my Aceca a LH window regulator.
There are other cars that use the same or someone have a usable one .
M
nicksonsticks
Re: Aceca Window regulator
« Reply #1 on: May 08, 2023, 22:51:31 »
Hi, Not sure if this is going to be of any help or not but I stumbled across an article about mga coupe window winder mechanism, it mentioned that they now have a source for some of the internal gears etc. It could be possible at a guess that these might also fit your Aceca. Sorry I don't have a link but if you Google mga coupe window winder mechanism you should find the same info.
Kind regards Nick
MLeitao
« Reply #2 on: May 12, 2023, 15:59:36 »
Hi Nick,
Thanks for the info. Probably is the one  on the MGA Guru website, they have a contact for a someone in Germany that does new sector gears for the MGA. I think my oriblem is in the spindle. I have bough on Ebay some similar to mine. When they arrive, I woll dismantle them to see if there are any parts that I can use.
Best
Manuel
