AC Owners Club Forum > Ace, Aceca & Greyhound Forum
AC Bristol vs Bristol 405 Drivetrain
BEX1164:
Tony,
Thanks for the info, I’ll post pics of the transmission I can get from the 405. I believe the shifter top is different than AC ? If so, are the AC shifter tops available to swap out? And let know if this overdrive box is something I should use in my AC or if I should swap it with a smaller one.
https://flic.kr/p/2nn4D5z
BEX1164:
Here’s a couple more pics of the 405 trans, let me know f the photo link works for you.
https://flic.kr/p/2nn9Ucn
https://flic.kr/p/2nncuyZ
10kph:
The gearbox in the car has a shift extension but when undone will be like the one on the floor. The gearstick on the floor is correct shape so weld and bend the bristol one . The overdrive will fit ,note the vertical solenoid, but the rear support is different but again have seen this fitted using a different rubber block rather than a round tube.
Go ahead and buy !
Tony
BEX1164:
Thanks Tony
Glen Smytheman:
Andrew - have just sent you an email to three contacts in the USA that should be able to assist. Regards, Glen
Navigation
[0] Message Index
[*] Previous page
Go to full version
