Author Topic: How do you remove the Steering Wheel hub?  (Read 12112 times)
keithjecks
« on: August 05, 2007, 19:05:12 »
My 16/70 has something loose inside the steering wheel hub that sometimes catches, which can be unpleasant. I have been looking and looking, but I cannot see how you remove the centre that holds the advance/retard, trafficator switch, horn and headlamp switch. I am sure it can't be hard, but so far it has defeated me!
« Reply #1 on: August 16, 2007, 20:42:59 »
Phil Whitaker did complete PVT overhauls & i am shure he knows how, his phone number is
    01566 86776 , I am sure he will be willing to assist!
keithjecks
« Reply #2 on: August 17, 2007, 12:52:55 »
Thanks Robin - I will call him!
keithjecks
« Reply #3 on: August 19, 2007, 14:20:48 »
All done - once you know how, it is a 5 minute job!
« Reply #4 on: August 19, 2007, 15:52:42 »
How about letting us all know!
keithjecks
« Reply #5 on: August 19, 2007, 23:23:39 »
Good point! Well, the steering column is a series of concentric tubes. The inner one is connected to the light switch, the next to the advance/ retard, the next holds the steering wheel boss, the next is the steering tube and the outer is the column. To remove the steering wheel boss, first you have to loosen the a/r clamp at the bottom of the column. Then, at the bottom of the steering box casting itself is a clamp secured with a 7/16 nut and bolt. If you loosen this, the boss can be pulled back. That was all I had to do to remove the piece of metal jangling about (I still haven't figured out what it was, but am thinking it was the self cancelling mechanism for the trafficators). If you need to do more, you will have to deal with trafficator and horn wires which go down the centre of the column. I have not had to do this, but presumably tying string to them to pull them back with might work?
« Reply #6 on: August 20, 2007, 10:35:52 »
Great
   Thank You
