AC Owners Club Forum => Ace, Aceca & Greyhound Forum => Topic started by: alexG on August 09, 2007, 23:00:47
anyone know of a supplier for older style capiliary guage - 1954 car - with original bezel - not cobra type. Thanks for any ideas!
Alex,
I have a couple of extra gauges, but am unsure of the difference in the bezel. Can you tell me what should I be looking for and then I'll check to see what I have.
Originally posted by aex125
Alex,
Jay - thanks for contact. The older style has a slight slope to each side of the centre raised bit - something like a flattened pyramid. The newer slopes down to the glass, with the raised part on the outer edge. Hope that makes sense!
Alex,
I finally had a chance to look at what I have and there is 1 water temp and 1 oil temp gauge. The bezel is the same on both and looks like an inverted V. I also have a Smiths Jaeger Fuel gauge that has a bezel that is straighjt up on the outside and then slopes inward to the glass. From your description I think the temp gauges have the bezel you are looking for and if you agree by description, I'll take a picture for you so you can confirm.
Speedy Cables Can supply most Smiths, Lucas & Jaeger instruments & overhaul them in the UK 01639 732 213 ' www.speedycables.com '
