Author Topic: Koni damper/shock spherical bearing  (Read 4702 times)
Flyinghorse
« on: May 17, 2012, 22:39:33 »
Does anyone know of a supplier,or have a supply of the spherical bearings that go in the bottom lug of the Koni shocks as fitted to Mk3's , MkIV's and CRS (I dont know if all had the bearing installed)?
   Its "hand engraved" RBJ207L
   Google shows its a aviation bearing and I have some cross references (FL19716, PE53191-1ITEM75, RBJ207L, 3120992011162, 35NM47472, 4-27939, 992011162) so may be able to source locally.
   I will likley need for my MOT so its relatively urgent!
Flyinghorse
« Reply #1 on: August 14, 2013, 14:20:23 »
A few people are looking for this bearing. I think I have found a source of them ,reasonably priced with a sample on its way. Will post up the company's contact details when I know more in the next few days.
   Is everyone else's bearing the same as mine above?  It should be engraved on it & is easy to take out.
westcott
« Reply #2 on: August 14, 2013, 19:43:44 »
Hello Graham,
   I have the same code on mine.
   Thanks for posting the news, Uwe
SJ351
« Reply #3 on: August 15, 2013, 00:06:26 »
Alan at Thunder Road obtained mine for me recently.
Superarnie Mk2
« Reply #4 on: August 19, 2013, 23:43:23 »
Try;
   Autosport Bearings Ltd. 01932 22577
   I'm sure tey will be able to source item for you.
Superarnie Mk2
« Reply #5 on: August 19, 2013, 23:45:54 »
Sorry te correct number is:
   01932 225777.
Flyinghorse
« Reply #6 on: August 20, 2013, 23:58:16 »
Thanks Garry.
   I also have a source & reasonably priced so pm me if you want details.
Flyinghorse
« Reply #7 on: August 22, 2013, 19:59:21 »
I meant to add that on a CRS you only need 2 of these bearings for the rear. The front Koni's have metal/rubber bushes.
westcott
« Reply #8 on: September 02, 2013, 21:41:02 »
Thanks for your help and support Graham.
   Uwe
