SMF - installed December 2017.Returning members - please use the 'Forgot Password' function when logging in to the new Forum for the first time. If you have changed your email address please let me know so I can update it.
quote:Originally posted by Kiwi Cobra Hi All, Can anyone tell me what the switch assembly is for that's mounted on the clutch side of the pedal box? (its not the brake light switch). There is a plastic plunger that bolts onto the pedal lever. Mine is broken and whatever it does, it doesn't seem to be causing any adverse problem. Can I take it off permanently?. The Switch has the part number E6ZB-11A156 -AA EHI 7034B and is a Ford part. Thanks,Steve.
quote:Originally posted by Kiwi Cobra Thats it exactly thanks...I always check the car is in neutral before starting anyway so for me its probably redundant...
