Hello!
Working on an Aceca, but i gues the procedure is the same.
On the fron hubs, i pumped may be to much grease. I started pumping expecting to stop once the old and then new grease would flow trhough the rollers and then past the large washer under the castellated nut in the center of the hub. But despite pumping quite a lot i couldnt see any grease coming trough.
Should i pumpm more, untill when i dont see it coming trough? it is the right procedure?
I dont know the precise desing of the hub other than the drawing on the manual, and i dont think is the case, but could i had pumped too much and the grease escaped from the back and floaded the drum inside?
Thanks!!
Eddie
