Author Topic: Mk IV Hex Nuts  (Read 5567 times)
MkIV Lux
Mk IV Hex Nuts
« on: August 04, 2016, 09:02:53 »
Hi All,
   Does anybody have a set of hex nuts (hexagonal centre lock wheel nuts) for the Mk IV for sale? (2 left side and 2 right side)
   You can send feedback by p-m or to ccmngt(at)pt.lu
   Constant
Mk IV Hex Nuts
« Reply #1 on: August 05, 2016, 18:44:35 »
   Constant.
   Found you a Set of 4 x NOS Cobra Hex Wheel Nuts Complete with correct Spanner as supplied by AC Cars...[:p]
   Details emailed to you...[;)]
   Can collect on your behalf if required and despatch from work..[?]
   Cheers for Now
MkIV Lux
Mk IV Hex Nuts
« Reply #2 on: August 05, 2016, 23:52:54 »
Many thanks, Keith, will keep you posted
   Constant
Mark IV
Mk IV Hex Nuts
« Reply #3 on: August 09, 2016, 02:12:02 »
There were two different nut sizes used over the MK IV production and thus two different wrenches. Ask me how I know....
nightrider
Mk IV Hex Nuts
« Reply #4 on: August 16, 2016, 15:55:12 »
Originally posted by MkIV Lux
Hi All,
   Constant
jbottini
Mk IV Hex Nuts
« Reply #5 on: August 16, 2016, 21:54:20 »
Mark IV, evidently no one cares.jbottini
bobbylangley
Mk IV Hex Nuts
« Reply #6 on: August 18, 2016, 20:36:27 »
But it sounded financially painful...
Mk IV Hex Nuts
« Reply #7 on: August 18, 2016, 22:13:46 »
   MK1V
   Does it really matter if they are larger or smaller version, as long as you have a matching set of 4 (NOS) with correct spanner, You are home and dry..[;)].
   Assuming the thread is the same size and pitch the same .[?] Can't see any reason why AC would have changed?  Unless you know better [?].[?]
   Keith..
MkIV Lux
Mk IV Hex Nuts
« Reply #8 on: August 19, 2016, 00:12:44 »
Originally posted by AC Ace Bristol
   MK1V
   Keith..
   Hi Keith,
   First of all many thanks for your support on this. Sent you a PM.
   As to your  above remark: indeed it does not matter as long as the spanner matches the nut size.
   I was told there were 2 different outer dimensions, thread and pitch not having changed over time.
   Constant
Mark IV
Mk IV Hex Nuts
« Reply #9 on: August 19, 2016, 03:52:37 »
   MK1V
   Keith..
   Sorry,
   Do not have any nuts, only some sockets for them.
MkIV Lux
Mk IV Hex Nuts
« Reply #10 on: August 31, 2016, 13:47:26 »
Item closed, found what I have been looking for.
   Thanks for your help Keith!
