Author Topic: Cast iron welding  (Read 3257 times)
cliffordl
Cast iron welding
« on: June 19, 2013, 17:07:41 »
The manifold on my Frua has cracked - can anyone help with a recommendation to a cast iron welder in the south-east?
Klassik Metall
Cast iron welding
« Reply #1 on: June 19, 2013, 18:04:06 »
   I would not recommend having your manifold welded. Specialist cast iron welders are very hard to find and even then there are problems with distortion due to the high preheating temperatures required. If anyone offers you a plain arc welded or tig welded repair walk away, unless you want to have more cracks than you started with (don't ask me how I know).
   Occasionally an effective repair can be made by gas or tig brazing but this can also be problematic due to the casting having undergone many heat cycles and become semi porous.
   Possibly the most effective solution is metal stitching but it does depend on the location of the crack.
   Good luck with whatever method you choose.
   Regards Luke.
Cast iron welding
« Reply #2 on: June 19, 2013, 18:31:51 »
Slinden are probably the best in the UK for this work ' www.castironweldingservices.co.uk ' 01530274646 they are in Derby
Klassik Metall
Cast iron welding
« Reply #3 on: June 19, 2013, 19:09:14 »
Slinden look like they can offer exactly what you need welding wise.
   Just be aware that  some machining/refacing may well be needed after welding.
Cast iron welding
« Reply #4 on: June 19, 2013, 19:25:03 »
Web address should read http://www.castironweldingrepairs.co.uk
   Take some time to look through some of their repairs...VERY interesting range of problems to test their capabilities!
Cast iron welding
« Reply #5 on: June 20, 2013, 02:30:37 »
   Slinden Services Ltd  Dry stitched my Bristol 100D2 Block many moons ago,(Approx 20000 miles ago).great reliable, professional service.
   They weld, stitch, crack test , machine etc.. etc....... Worth checking out their web site.
   Rest assured, They do know what they are doing.
   Speak to David Russell...01530 274646
   email:-  info@slinden.co.uk.
   www.slinden.co.uk
   Unit 10, Riverside Court. Westminster Ind estate.
   Measham, Derbyshire,  DE12 7DS
   Keith..[:)]
cliffordl
Cast iron welding
« Reply #6 on: June 20, 2013, 18:03:17 »
Thanks for your replies - Slinden looks like the route to go down if I go for repair rather than replacement.
