Author Topic: Ace King pins  (Read 2444 times)
James Eastwood
Ace King pins
« on: November 25, 2017, 23:06:03 »
Hi chaps I've put BE475 up on axle stands for the winter to restore all the running gear. I've stripped the King's pins this evening (cotter pins - phew!) and they have quite a bit of play. Is there a bush kit available or a company that can correct then for me?
   I also have play in a rear hub lower pin joint on one side. It's not  yet apart, but is this a common problem and what is the approach to fix Please?
   Many thanks
   James Eastwood
   200 GPD  /  BE475
TTM
Ace King pins
« Reply #1 on: November 26, 2017, 08:29:27 »
Good morning,
   I sourced a set of king pins including bushings from Brian Eacott, tel. 020 8397 8472
   Hope this helps
James Eastwood
Ace King pins
« Reply #2 on: November 30, 2017, 14:48:05 »
TTM thanks, I spoke to Brian and now understand that he offers a range of suspensions bushes, repair kits and other parts including brake hoses. I've arranged to send him my list of requirements once I have finished dissembling the suspension.
   James Eastwood, BE475.
