AC Owners Club Forum => Mk IV, Superblower, CRS and other Continuation Cars Forum => Topic started by: twogreens on September 16, 2007, 23:23:47
Two of my Halibrands are looking pretty tatty these days - corrosion seems to have gotten under the lacquer. Can anyone recommend an alloy wheel refurbishment firm (preferably in Essex)?
Regards to all
Two Greens
Sorry, not in, or even close to Essex, but my Dad had his Mustang wheels refurbed by LAP-TAB (http://"http://www.lap-tab.co.uk/alloywheels.php") in Birmingham, and rated them very highly. I can recommend Parcel2go (http://"http://www.parcel2go.com/?referrer=html_2-4_New_rate_07&email=html_2-4_New_rate_07") as a courier, very good on price.
Hi Two Greens,
Have a look at the Spit and Polish website
http://www.spitandpolish.co.uk/
They are in Kent but provide a collect and deliver service. Thunder Road use them and are happy with their work.
All the best - John.
Well, after umming and r'ing I sent two of my wheels away to a company in Herts to be diamond cut - they eventually came back and I am very disappointed. The machining itself appears to be very good but the relacquering looks like it was done in a very dusty environment. Can anyone recommend a way to remove wheel lacquer?
Rick
Hi Rick,
My neighbour's tom cat is very efficient at removing the lacquer from my wheels and I would happily send him to you (parcel post)[}:)].
On a more helpful note, I have just had my wheels partly refinished by a local (Surrey) company. I chose to leave the painted centres untouched and had the rims mirror polished. I am pleased with the results. I chose not to have the finish re-lacquered this time on the basis that I'll see how much of a pain it is to keep them clean and bright. If it proves too impractical then I can always have them cleaned and lacquered later.
John.
For alloy wheel restoration, one of the best companies in the UK is Pristine, who are located at Woburn Sands which is just outside of Milton Keynes. The are OEM refurbishers and do work for major car companies such a Mercedes and Aston Martin. The often restore the all alloy wheels some of my customers Shelby vehicles use. As to the maintenance of the alloy rims, I recently located a clear laquer specifically designed to go onto polished aluminum surfaces. I have used this on my own 15inch Halibrands and the finish is superb. The downside is that you have to key the surface prior to applying the laquer which means some sort of surface scuffing to get that key. On my own wheels this preparation was done carefully and along the rim line so with the laquer applied the effect is lovely, however you do get a more satin finish which may not be to everyones taste.
John, I followed your advice and had the rims refurbished by Spit & Polish when my car was in with Big Al for some work on the brakes. Am a happy man again!
Seasons Greetings to all
Rick
AKA Two Greens
