Author Topic: Fuse box - fuse capacity  (Read 588 times)
SpqrEddie
« on: December 28, 2022, 08:38:48 »
Hello!
the instructions mention two 25 and two 50 amps fuses.
but they dont mention where! and the electrical diagramm neither.
Do you know in wich position the two 25 and the two 50 amps fuses should go?
Thanks!!
« Last Edit: December 28, 2022, 11:44:37 by SpqrEddie »
Re: Fuse box - fuse capacity
« Reply #1 on: December 28, 2022, 10:23:46 »
Eddie
Fuses
1     Turn indicators Brake lights    25Amp
2     Wipers Fuel Gauge                25Amp
3     Horns                                   50Amp
4     Side Lights                           30Amp
on Lucas wiring Diagram W31520A Feb 1957
( 1 to 4  left to right on diagram , the fuse size written in pencil  in 1964, by previous owner ) ;)
Hopefully  the above is useful,
SpqrEddie
« Reply #2 on: December 28, 2022, 11:45:31 »
Thanks Keith!
will follow the wire and make sure they are on the same order!
Thanks!
Eddie
