Thanks Keith,
Well I have installed the outer ones dry, but before reading this I used the red stuff on the centre one, Now I don't know whether to dismantle and use silicone based or continue and see if the red stuff works.
I mean it says on the packet that it seems to be ideal for this job, well you learn by your mistakes so unless there's a clear (chemical or physical) reason not to use the red 'stuff' then I'll continue with assembly.
Will obviously let you know how it goes!
Keith Penny.
