Author Topic: rack and pinion  (Read 3286 times)
nashvet
rack and pinion
« on: January 30, 2014, 22:35:23 »
I read on some site about a Mk IV that had quick ration rack and pinion installed.  Does anyone have any more info along this line.  I would like a quicker ratio for use in autocross events.
SJ351
rack and pinion
« Reply #1 on: January 31, 2014, 00:08:18 »
It is a modified MGB rack. You should be able to get a quick rack from Moss.
nick Godridge
rack and pinion
« Reply #2 on: February 01, 2014, 10:56:39 »
Interesting.
   How does it need to be modified?
   Nick G
French Frie
rack and pinion
« Reply #3 on: February 01, 2014, 11:37:23 »
My understanding it is a genuine MGB rack, but with hexagonal part added between rack and track rod ends to cope with the larger front track, but I also remember that another reference for the rack was mentioned in the part list we already talked about here...
SJ351
rack and pinion
« Reply #4 on: February 01, 2014, 16:19:34 »
You will have to buy a quick MGB rack I believe and then cannibalise the rack and pinion into your existing rack via a steering rack specialist. My MK1V race car has one but It was already in place when I got it.
Rob.Hendriks
rack and pinion
« Reply #5 on: February 04, 2014, 01:48:26 »
Gents
   The MKII classic uses exactly the set up described above i.e. standard MGB rack, with shortened re-threaded tie rod ends, a hex extension piece (obviously the standard tie rods are not quite long enough) and I do not know if this is applicable in your case, but the socket end of the tie rod is also machined to allow the rod increased travel.
   Should anyone be interested I have the drawings for this installation
rack and pinion
« Reply #6 on: February 04, 2014, 09:17:01 »
Originally posted by Rob.Hendriks
Gents
   The MKII classic uses...a hex extension piece...
As did the Greyhound, 50 years ago!
   (As previously posted in the '15" Wheels' thread.)
