AC Owners Club Forum => Mk IV, Superblower, CRS and other Continuation Cars Forum => Topic started by: cobra06FR on October 12, 2017, 22:36:45
Dear All,
On my Autokraft AC MKIV I have a 302ci converted SVO. The current oil pan is a 5 quarts volume and I would like to increase the size of this oil pan to 7 or 8 quarts
Has anyone done that before and if yes, what oil pan brand/reference did you install.
Many thanks for your advice.
Best Regards
Cobra06FR
The 302 has a double hump pan, as a crossmember runs under the centre of it. I've not done what you anticipate, but there will be one here of increased capacity
https://www.summitracing.com/int/search/part-type/oil-pans/make/ford/engine-size/5-0l-302/engine-family/engine-family?N=4294951399&retaillocation=int
Hi Laurent,
Nice to see that you can now write about "your" AC MkIV. Just for my understanding, what are you after: - better cooling? - longer oil change intervals?
Constant
Hi MkIV Lux,
Yes I now have had the car for 2 weeks, and have already done almost 1000 km. Works really well. Very different from my Backdraft replica though.
About the oil pan, the previous owner mentionne dthat he felt the volume of oil (5L) was not enough. I raised the question with my mechanician and he also agreed that a 7L oil pan would be much better. However, as the cahssis of the car pases just under the oil pan, I wondered if someone had changed it already and could advice of a model that fitted the car chassis. I don't want to uy one the does not fit.
On a similar note, I wonder if you have chaged your igition distributor laready. Usually to avoid getting stuck on the road, I have few parts in the boot of the car. The ignition coil is one (I found it) and the ignition distributor is th eother one.In this case I cannot find it - the reference is motorcraft E5ZE 12127. Do you have an idea where I coul dfind it ?
Thanks and looking forward meeting you.
BR
L
Try Aviaid sumps, if they don't have something off the shelf, they can do a custom sump
http://aviaid.com/shopsite_sc/store/html/ws_oilpns_sbf.html
Contact: Stephanie Steinberg
Email: stephanie.aviaid@aol.com
*In no way related to this business. I have fitted one of their Cobra sumps and am very happy with the service and result
Originally posted by cobra06FR
Hi MkIV Lux,
Yes I now have had the car for 2 weeks, and have already done almost 1000 km. Works really well. .............
BR
L
Hi Laurent,
I'm glad you enjoy your new mount [:)]
For the distributor and coil: no I don't carry a spare. Never had any problems.
Quick google check on the part number: how about this?
http://www.ebay.com/itm/New-Distributor-for-Ford-5-0-302-Mustang-GT-1986-1993-/181729603933?fits=Model%3AMustang
Meeting you with your new toy would have to be somewhere in the middle of France or on the route Napoleon ... as we are some 1000 kms apart. No challenge for a MkIV [:)]
Constant
Hi Laurent, I have a Moroso 7qt kicked out and baffled sump on my Superblower. If memory serves me right the part number was 20502??
Many thanks Gary,
Very usefull. I'll look for this one.
BR
Laurent
Hi Laurent,
I have a 7 qt Canton Road Race T-Pan rear sump on my 331. It is baffled, kicked out and has trap doors around the pickup, here is the link:
https://www.cantonracingproducts.com/cgi-bin/commerce.cgi?preadd=action&key=15-644
On my former Clevelands I used Moroso products, can recommend both companies.
