AC Owners Club Forum > Ace 'Brooklands' Forum
Rear spring dimensions and rates
AcemanToo:
Does anyone have information on the rear coil springs on the Ace Brooklands please? I'm looking to get some uprated ones to try and stiffen up the suspension and get rid of the well-known 'thump' at the rear end. Trouble is, I don't quite know where to start! If anyone has any information no matter how trivial, please help with some answers!
Many thanks!
paho:
I looked at topic "Spring rates", https://www.acownersclub.co.uk/forum/index.php?topic=2752.0 ,
when replacing my coil-overs. I had to translated the spring rate figures given to metric
measurements and assumed the weight of the car to be 1720 kg without spare wheel.
(its actually 1668,5 kg with me in the driving seat and half a tank of petrol, 1590Kg without.
Weight distribution is 50,13%/49,99% respectively).
The old shocks and springs were checked by SDV in Dalarna Sweden and the results were close to the figures in the topic.
So the coil-overs were made up to these specs. The origonal Koni coil-over kit is not manufactured any more.
The origonal coil-overs on my 1995 model looked pretty tired after twenty odd years of service,
rusty with the bumpstops disintegrating and one front shock absorber leaking slightly.
I found the car sat unevenly after I fitted the new coil-overs, so I wish I had measured the ground clearance
before fitting (could'nt use the old springs as we reused parts of the old Koni shocks). The handbook states 15cm,
but I have not managed to match that so the clearance is 13,5 passenger side, 14cm drivers side without driver.
I'm happy with the result, the ride is firm but not bumpy, and seems to clear sleeping-policemen better, which it didn't before!
Br /Paho
Max Allan:
Hi AcemanToo
When I tackled the suspension probs many years ago I found the rear shock absorber travel was not equal distance above and below ride height (I decided on three fingers gap between tyre and wheel arch which equates to about 4 inches) – there was less travel from ride height to bump stops compared with suspension fully extended. To obtain equal travel I relocated bottom shock mountings closer to wheels ( I welded the brackets directly above the tube linking the two wishbone arms). I retained the original Konis and springs, but had several different thickness spring packings machined to bring the car up to desired ride height.
Did the same with front suspension – relocated the shock lower mountings further out to achieve equal travel above and below ride height and fitted longer Konis to suit increased distance between upper and lower mountings and to increase suspension travel. Finally had new springs made to achieve 1) correct ride height 2) accommodate extended travel 3) eliminate coil binding issues.
Not had issues with grounding or hitting bump stops on normal roads since.
Hope that helps.
Nev:
The previous owner of my car did a lot of work re springs etc (calculations etc etc) , he was an engineer and seems to have been a bit of an expert on this topic. I can have a look through the file and share info. I had a leaking shock, so went for the set up that Redline have specc’d and had made, I now a couple of other members have the same set up , seems good, I have never experienced the thumping, but I don’t think this one has never done it since George put on the revised coils and springs he had made up.
AcemanToo:
Hi Paho,
Many thanks for your reply and links to past answers! Apologies also for the lateness of my reply - simply forgot which is really no excuse at all when you've taken the trouble to help me.
It was very interesting to read that the spring coils are too close together on the rear springs - it certainly helps explain why the back end makes so many thumping noises when the road isn't as smooth as glass!
Do you know if the springs were tailored to the Ace or were they just picked off the shelf somewhere, maybe XJS or similar?
Once again, grateful thanks!
Navigation
[0] Message Index
[#] Next page
Go to full version
